NI GPIB causes kernel panic in OSX10.5.2
Running the latest version of the NI GPIB drivers for a PCI-GPIB card in a PowerPC machine. Everything works fine under OS 10.5.1, but when I upgraded the machine to 10.5.2, reading anything from the GPIB bus caused a kernel panic. Writing was fine, but any attempt to read immediately killed the OS. I tried this on two separate machines (a G4 and a G5), using two different cards, with the same result. I'm now in the process of reverting to 10.5.1 until this can be fixed.
The GPIB Troubleshooting application reported no problems. The card was accessed using LabVIEW 7.1.
The relevant crash log entry:
Unresolved kernel trap(cpu 0): 0x300 - Data access DAR=0x0000000038D5D11C PC=0x0000000000658BD8
Latest crash info for cpu 0:
Exception state (sv=0x29FB6780)
PC=0x00658BD8; MSR=0x00009030; DAR=0x38D5D11C; DSISR=0x42000000; LR=0x0061B064; R1=0x1272B460; XCP=0x0000000C (0x300 - Data access)
Backtrace:
0x00000002 0x00BD909C 0x00BD33D0 0x00BE8BAC 0x00BE35C0 0x00BE4F4C
0x005C3AE8 0x005C5298 0x005C50D0 0x005C6550 0x006016A8 0x00601574 0x00601B0C 0x00657788
0x002BE804 0x002CFE70 0x002BEF38 0x002BDF4C 0x002BDE5C 0x002CDFB4 0x002CE230 0x002CE300
0x002ECAD4 0x0008DD60 0x000291C0 0x000233AC 0x000AC0AC 0x00000000
backtrace terminated - frame not mapped or invalid: 0xBFFFF650
Kernel loadable modules in backtrace (with dependencies):
com.ni.driver.gpibprtk(2.3.1)@0xbd0000
dependency: com.ni.driver.nipalk(1.9.1)@0x5ab000
dependency: com.apple.iokit.IOPCIFamily(1.7)@0x45d000
Proceeding back via exception chain:
previously dumped as "Latest" state. skipping...
Exception state (sv=0x29DC6280)
PC=0x9000B268; MSR=0x0200F030; DAR=0x00302010; DSISR=0x42000000; LR=0x9000B1BC; R1=0xBFFFF650; XCP=0x00000030 (0xC00 - System call)
Kernel version:
Darwin Kernel Version 8.7.0: Fri May 26 15:20:53 PDT 2006; root:xnu-792.6.76.obj~1/RELEASE_PPC
panic(cpu 0 caller 0xFFFF0003): 0x300 - Data access
Latest stack backtrace for cpu 0:
Backtrace:
0x00095718 0x00095C30 0x0002683C 0x000A8404 0x000ABD80
Backtrace:
com.ni.driver.gpibprtk(2.0
(4,595 Views)
The latest version of the 488.2 drivers for the MAC X OS is 2.4,
however this only supported up to version 10.4.2 versions of the PowerPC MAC X OS
For versions of 488.2 drivers along with compatible OS please click here.
Until support is added for the 10.5.2 OS version you should probably revert back
to your old set-up.
Let us know if you need anything else.
Christian A
(4,558 Views)
Thank you for the response. Does NI plan to support 10.5 for PowerPC in some future version of NI-488, and if so, is there any estimate as to when that might be available?
(4,553 Views)
I have asked and as yet there are no plans to add support for the MAC X 0S 10.5.2
Our R&D department would consider adding support for your OS if enough requests are make.
To make a request please fill out a Product Suggestion found here.
Christian A
(4,539 Views)
I just found this thread...  Thanks for TAGS!
Actually there were plans at that time to add support for Mac OS X 10.5.X.  As you may know, the latest drivers GPIB 2.5.5  support 10.5.X on Intel Macs but only 10.4.X for PPC Macs.
HTH
LabVIEW ChampionLabVIEW Channel Wires
(4,105 Views)
