NI 5772 Adapter Module PC Connection
I am new to using FPGAs and new to using the NI 5772 Adapter Module.
I do not own the NI FlexRio FPGA but I do own a  KC705 Xilinx FPGA and wanted to know the best way to connect the Adapter Module to my PC.
In the NI 5772 manual it reads:
"The AUX I/O connector accepts a standard, third-party HDMI cable, but the AUX I/O port is not an HDMI interface. Do not connect the AUX I/O port on the NI 5772 to the HDMI port of another device."
Is it safe to connect this to my PC via an HDMI cable or is there a better/safer way to receive the digitized data?
Any help would be greatly appreciated, thanks for your time.
(3,213 Views)
The KC705 Xilinx FPGA has an output HDMI port. Output to output isn't going to work.
What are you looking to do?
ALE Consultants
(3,190 Views)
I'm trying to take data from an external source from analog to digital using the NI 5772 Module to my PC or the FPGA to then connect it through to Simulink. But the ADC that comes with the K705 FPGA only goes up to 1 Msps which isn't high enough so I was trying to use this adapter module.
(3,127 Views)
The 5772 is a FlexRIO Adapter Module and needs a FlexRIO card.
ALE Consultants
(3,123 Views)
