NI 488.2 Drivers not installing correctly on MacOS 10.13.1
Hi all,
I've been trying to install the NI488.2 drivers for GPIB instrument control on a system running the latest ver sion of macos (10.13.1) and have so far been running into the same issue. No GPIB instruments are detected (standard USB is fine) and the 488.2 trouble shooting wizard states that the 488.2 drivers have not been installed correctly. I've tried multiple restarts and reinstalls and have also tried completely uninstalling both the 488.2 drivers and the standard NI-VISA driver before reinstalling. No luck so far with the troubleshooter always returning the same issue.
I'm wondering if this might be a problem with running the latest version of macos? If anyone had any bright ideas that would be great!
(2,718 Views)
Hi Telthor,
Could you provide the link for where you downloaded those drivers?
Also does it show up in NI max that it has been installed already?
(2,691 Views)
