After the controller has asserted REN, even if it transmits Listener Address to NAT9914, it does not shift to REMS. Although neither LPAS bit of ADSR nor LADS bit changes, if Talker Address is transmitted, TPAS bit and TADS bit will be set.
When using RLC Interrupt, is special initial setting required? Please let me know someone.
