Most recent serial drivers for LV4?
Hi All,
I am trying to communicate with a non NI serial device from labview 4.0.1 using a usb to db-9 serial converter cable. The device wants a baud rate of 115,200.
NI-VISA 2.0.1 VISA interactive control for LV4 DOES communicate with device at 115,200. However, The device is not recognized even when I do a write from the preprogrammed ni serial vi's. I have double and triple checked the settings. I have also completed the loopback test, but that would also fail stating "device not found".
Can I communicate with this serial device with old versions of labview?
notes:
It does work when programming a vi with the student edition LV7.1.
thanks,
Stuart
(3,519 Views)
What functions are you using in LabVIEW to try to communicate? There are the serial read/write fucntions and the VISA read/write functions. The serial read/write functions are obsolete and no longer supported by NI. It's possible that these older serial functions don't work with USB->RS232 converters but if you can communicate with the VISA interactive control, you can use the LabVIEW VISA functions to do the same thing.
(3,513 Views)
Dennis,
I gave up on the serial read/write functions and used VISA and it is working great. Thanks.
Stuart
(3,499 Views)
Glad you got it working. If you ever upgrade from 4.1, that's one less thing you'll have to worry about since the newer versions of LabVIEW only have VISA.
(3,496 Views)
