Modbus Labview limitations
Our system runs Labview v6.1/C++. In the grand scheme of things, our system will be a MODBUS (RS-485) slave device. I wanted to know what was the best way to send labview variables across MODBUS to the master device. I saw the Labview MODBUS VI. We have about 300 data points that will be sent to the master device. My main questions are:
- Is there a limitation for information that is being sent (ie. number of holding registers that can be read simultaneously etc)
- If this VI wont do it, what is an alternate solution?
- The master device doesn't run labview, they probably ping for data in some custom written code (still would use MODBUS commands). Can Labview send information when pinged by a system that doesnt run labview? In other words, would Labview with this VI (or any other solution) respond to a MODBUS request command to the serial port irrespective of its source?
A response would be highly appreciated. Thanks a lot in advance.
(3,942 Views)
The limitation is most of the time the programmer not LV.  Smiley Tongue  (wisdom from own experience)
If the ModBus library has a limitation for your application then you can always modify it or write your own dedicated ModBus program. The last I did for our ModBus modules with non standard commands.
300 point is can not be a problem.
A ModBus slave programmed with LV is just a ModBus slave. It will answer to a ModBus master regardless in what language it is made.
So if the ModBus library is not sufficient for you have to wire same code yourself.
(3,928 Views)
There was (is ?) an error in the library that causes a limitation. Please see the readers comments on this page for more details.
(3,914 Views)
