Missing Card Error
Hi!
Is my card broken?
The cables were correctly connected to instruments,
but I got nothing when I "scan for instruments" from "Explore GPIB".
Then I tried to use "GPIB analyzer" from the menu, but it showed me the message:
"Supported GPIB+ interface not found. Supported GPIB+ interfaces include PCI-GPIB+ and......".
 The problem disappeared if replace another card.
Thank you for your help.
(3,544 Views)
It sounds like you might have two separate problems here. We'll take care of the "scan for instruments" failing second. First, what GPIB cards are you using? If you installed a PCI-GPIB card (for example), you would get the "Supported GPIB+ interface not found. Supported GPIB+....." error if you ran the GPIB Analyzer because only GPIB+ cards support the GPIB Analyzer. Swapping in a PCI-GPIB+ card would remove this problem.
If you put the original (broken?) card in another slot or another computer, is it able to scan for instruments?
When you swapped the cards, did you keep everything else constant? Did you test it with the same cables and the same instruments?
If you're using the same cables, same instruments, same computer (and same type of card) in both tests and you're able to scan for instruments on one card and not the other, you may need to RMA this card. You would create a phone support request here. I hope this helps!
Missy S.
Project Engineer
RoviSys
(3,515 Views)
