Max doesn't add cp2102 device
Why would you reinstall LabVIEW? If you were to reinstall anything, I would start with the USB driver, then NI-VISA, and then MAX.
Message 11 of 16
(1,760 Views)
Is the device's virtual COM port (VCP) showing up in Device Manager?  Can you communicate with it through an interface like HyperTerminal or PuTTY?
Honestly, it sounds like the driver's not installed.
If I remember right, the driver you download is just an installer for the driver.  There's a check-box in the downloaded installer to launch the VCP driver installer that isn't checked by default, so if you just next-next-next-finish through the installer the actual drivers probably aren't installed.
Message 12 of 16
(1,754 Views)
Yes, I communicate with Hyperterminal very well, where do i find the driver for recognize the CP2102 in MAX?
Message 13 of 16
(1,751 Views)
Is this link http://joule.ni.com/nidu/cds/view/p/id/2914/lang/it ok for NI-VISA driver?
Message 14 of 16
(1,746 Views)
If you're talking to it with HyperTerm/PuTTY, the VCP drivers are installed.  You're communicating with the device as a COM port.
Take that COM port and bring it into LabVIEW as a constant into the configure-serial-port.vi.  See the example I posted, but I don't see anything wrong with what you did either.
Message 15 of 16
(1,739 Views)
Ok, I resolve the problem, i installed the NI_VISA and the block diagramm works!!
Thanks to all
Message 16 of 16
(1,732 Views)
