Max GPIB Vs LabView GPIB
Hi all, I'm working on a program to read and write to a piece of equipment using GPIB.
At the moment NI Max does not pic up that the device is connected through GPIB but the labview program does.
Origionally I thought that the computer was not regestering the GPIB PCI Card but when I went into device manager it showed that the computer was picking up on the card.
Is there a reason or setting at to why max does not pick up the GPIB device and the labview program does??
The meter is GPIB0::11::INSTR
Please find images attached, and any advice would be helpful.
Thank you.
T.J.
(6,031 Views)
MAX uses the low level functions from NI-488.  LabVIEW populates the IO control drop down from VISA calls.
That ADLINK device does not play nice with NI 488 although it's VISA implementation does follow VISA conventions.
(Buy cheap get cheap)
"Should be" isn't "Is" -Jay
(6,028 Views)
Hi Jeff, thank you so much for replying.
So what you are saying is its the actual PCI card itself?
Thank you.
T.J.
(6,023 Views)
Why would you expect an NI program (MAX) to be able to detect and configure a non-NI device. Since LabVIEW is using the VISA driver, you have no problem at all.
(6,017 Views)
Try: MAX-> Tools -> NI VISA-> VISA Options, you'll see the configuration pannel, then General Settings -> pass-ports, you'll see a List of Pass-ports, make sure tick up all checkboxes. (GPIB Pass-port is un-checked defaultly.). Then save & exit, relaunch MAX, you might be able to see your third party GPIB card.
It works for Agilent any way.
Good luck.
O...Dear, why the word "pass-port" is not permitted!!!...
Be True!
(5,958 Views)
