MVP2001
Good day all,
I have attached a pdf of an example I am trying to use to run my motor. It is under the palette of I/O instruments. I have downloaded this from the instruments device driver with the aim of controlling an MCDC3006S (Driver) to drive a Faulhaber motor. Please kindly help.
Thanks in anticipation.
(3,791 Views)
Help with what? You need to ask a question.
(3,789 Views)
What I mean by help is that, I have my hardware connected (A driver MCDC3006S) to a faulhaber motor (brushless DC motor). In the MVP2001 file that I have quoted as the subject, I got this example. Now with the proper connection of the hardware, I believe running the Vi is suppose to run my motor but this is not happening (when I run the Vi: my motor is not running). And thus, I would somebody to explain how to use this example on hardware. Thanks once again.
(3,786 Views)
Hi Dennis,
Still waiting for your response. The examples in the MVP2001 just keeps running continuously without moving the motor. What can I do. I send the right command but its still not working. I tried using advanced serial write and read vi in serial communication and it worked. My only problem is how to send those command pragmatically and not manually that I am doing now. When I send the command one at a time it actually control the motor, but I want to send them and programme the motor to work according to the commands without my input.
(3,769 Views)
