MMA 7631 accelerometer with arduino uno
hello,
I am trying to develop the vi for accelerometer , i have developed a sample vi but it is showing error again and again. i tried to figure it out but unable to solve. i am having MMA 7631 accelorometer and arduino 7631. i am ataching a vi. please reply for the issue. i have even used firmware for accelerometer too. check out the attachment too.
(6,331 Views)
i am not getting any of the errors specififed in your link secondly i am getting a error as data in unexpected form. As per my VI i developed its approximately right, but while scaning i am getting that error.
(6,319 Views)
What error? You can't expect much help if you don't provide the exact code and message. If you are getting an error with scan from string, provide the exact string that you receive.
(6,316 Views)
I gave you that link because that is message board that NI has set up for people using Arduino.
The folks there should be more knowledgeable.
Most people who post on this message board do *not* use Arduino.
(6,312 Views)
according to my vi i should get data in the format of %d %d %d %d, decimal integer. For some time it runs properly and after than unexpected data format comes in the form of symbols. that is the issue.
(6,297 Views)
