09-13-2005 07:31 PM
09-14-2005 07:19 AM
Doesn't sound like a RS232 communication..., however you seem to have a cable to plug in the RS232 port
So I assume the device is using the hardware handshaking lines (DTR,CTS,CTR...) to establish a communication with DI,DO&CLK and some voltage level circuitry is build in the rs232 plug. Correct?
Then the next would be to find out what RS232 line is used for DI,DO&CLK and use the VISA property node to toggle the lines, resp. to read the line status to send and receive data.
09-14-2005 06:51 PM
Hi Henrik,
You are right, there is a converter between RS232 to MDIO. I will follow your suggestion. Need to ask my friend about D1, D0 and clock.
Thank you so much
Scott F
09-15-2005 03:38 AM
A nice general information on rs232: http://www.arcelect.com/rs232.htm
or search the NI site.
One way to find out: With a scope compare the flow control lines with the MDIO lines to find out which lines are used.
Dno't be afraid to rate a good answer
01-06-2010 03:54 AM
01-06-2010 12:27 PM
Kevin
This is a 5 year old post. It's ok to start a new thread
