MAXstoppedserviceerror
I often get an error message MAXStoppedServiceError after starting MAX. I have tried to restart the service NI Configuration Manager, but after restarting this service it stops. The only solution that works is to restart the computer, but mostly I have to restart the computer several times before NI Configuration Manager runs. I have installed all the critical updates, but it did not help.
The same problem I described in http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Unexpected-Error-in-NI-MAX/m-p/2495118 , but now I don´t get any error message about GPIB.
I use Windows 7 and LabView 2013.
Do you have any ideas?
(5,375 Views)
Dear Petrm,
the problem you've described can occur for a few reasons, mst of which can be fixed by Cleaning MAX data and/or Repairing our insallaion. Some firewalls can also stop the servce connection from running properly.
Please consult this KB for troubleshooting steps. If te issue persists, let me know.
Kind regards:
Andras Valko
NIH
Andrew Valko
National Instruments Hungary
(5,340 Views)
we have NOD32 antivirus version 4.2.76.1, but according to https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MZtSAM&l=en-US port 3580 is not in the list. "Automatically detect HTTP communication on other ports" is not present in the settings in this version.
We use Windows 7 firewall as well, could this be the cause of the issue?
Petr
(5,334 Views)
Dear Petrm,
there's only one way to know for sure :-). Also, any results from the other troubleshooting steps I suggested?
Regards:
Andrew Valko
Andrew Valko
(5,299 Views)
