Lecroy waverunner -scope using labview.
Hi , I am currently using a lecroy waverunner 104Xi . I went to the insturment driver network to download the drivers for the scope . the drivers are from http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=10978 . Could anybody tell me how to proceed from here , to read waveforms from scope , I would like to adjust trigger , scale , and coupling . Any body that has done this , could you guide me through the process . I currently have labview 8.6 installed.
Thanks for the help.
(3,662 Views)
Hi Fitch,
I have this instrument driver installed; there is an examples section in this instrument driver. If you place one of these examples you can double click on it and look at the front panel and block diagram to see what they did to set it up. This should help you if you’re just getting started with LabVIEW and instrument control.
Matt
Matt
(3,641 Views)
