02-02-2017 08:50 PM
Hi, I am trying to interface with the wavesurfer 3054 which only has the option for TCP/IP connection. I have installed the VICP passport however my machine does not accept the resource string VICP::ip address. Using the string TCPIP0::ip address::inst0::INSTR works however it only outputs WARNING : CURRENT REMOTE CONTROL INTERFACE IS TCPIP. Any help to fix my issues would be greatly appreciated.
02-02-2017 08:51 PM
Forgot to mention when I use the VICP::ip address string the error is simply:
VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
02-03-2017 04:43 PM
Hi Mican,
Have you seen the following community post? It seems very similar to your issue.
Can you ping your device?
02-05-2017 04:30 PM
Hi Kodester
Yes I can ping my device, what community post are you referring to? Did you mean to link one, if so I may have already seen it as I have tried looking at all the posts I could find and couldn't fix my issue that way.
11-28-2017 02:31 PM - edited 11-28-2017 02:32 PM
Hi Mickan,
I am receiving the same message. Did you ever solve this? It is happy to respond to *IDN? but anything else the response is WARNING: CURRENT REMOTE CONTROL INTERFACE IS TCPIP
Nick
11-28-2017 03:17 PM
Sorry I never managed to fix it and ended up swapping to another piece of equipment.
