LabVIEW and OceanOptics USB2000
Hi everyone,
I am a new LabVIEW user and I am trying to drive the USB2000 spectrometer with LabVIEW.
and I was able to use the USB4000 (which is the older spectrometer model) with the VIs provided with the drivers. I also modified the "acquire continuously" VI adding the possibility to adjust the integration time.
Everything worked fine until I switched to the USB2000 (for its better optical resolution) and I found out that it seems "impossible" to both set the integration time and acquire the sampled spectrum. If I use the basic "acquire continuously" VI it works fine: on the other hand, when I try to add the integration time regulation, it returns me only the first sample. Then, for the following cycles, it remains stuck waiting for the "read optical spectrum" VI results.
I wonder if there is a different procedure to follow in order to set the integration time while acquiring the spectrum (which is a basic function for a spectrometer!) or if I am missing something.
I attach the zipped VI that I modified (the one that works correctly with the USB4000).
Thank you all in advance!
(5,717 Views)
Maybe the problem is in the value of the integration time.
The 2000, if I remember correctly has microseconds instead of ms timing and a too small integration time is just not good.
greetings from the Netherlands
(5,686 Views)
Hi Luca,
did you try to reinitialize VISA resource to set new integration time?
Did you notice any kind of delays?
Kind regards.
Cla_CUP
(5,662 Views)
