Keysight 81150A Multifunction Arbitrary Generator
Please if someone can help me I have to work with this generator to generate a waveform and I do not know how to do it is the first time thanks
Message 1 of 8
(5,592 Views)
Do you know how to manually use the instrument? You will not get far if you don't.
Did you find the driver for the instrument?  Spend some time studying it to find the functions you need.
Message 2 of 8
(5,587 Views)
As long as you know which buttons to press in order to set the instrument up to get your desired waveform, it is relatively easy to program it remotely.  This instrument accepts SCPI commands and it spells those out in the Keysight User's Guide.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 3 of 8
(5,567 Views)
Thanks to all of you to answerd me, i didn't find much can you plz quide
Message 4 of 8
(5,549 Views)
The Internet is your friend.  This manual, Keysight 81150A User's Guide which can be found at: http://literature.cdn.keysight.com/litweb/pdf/81160-91020.pdf?id=2026276 was simple to find.
Message 5 of 8
(5,543 Views)
thank you for answering me . the problem it's no the generator but how to link it with labview how to programme it with labview
Message 6 of 8
(5,519 Views)
Message 7 of 8
(5,519 Views)
The instrument has 3 interface option for connecting and communicating with the device.  If this is the only instrument, I would go with the USB connection unless you have a preferred interface.  Then I would use SCPI commands for controlling this instrument with some very simple code like this.
VISAwrc.pngThe other case is [-1] without the braces.  It passes the write to the read and the VISA Write to the Close.
Once the instrument is powered and connected, load the write buffer with the following:
*IDN?\n
The instrument should respond with something similar to: Hewlett-Packard 81150A,... or Agilent 81150A,... or Keysight 81150A,...
Couldn't get much easier.
Message 8 of 8
(5,515 Views)
