Joystick use
hello,
I need to control the slides in attached VI  by a joystick. Is it possible?
thanks
(3,955 Views)
Yes
and in earlier posts Dennis pointed you to the joystick keyboard input routines and examples in LabVIEW.
Please search the examples yourself.
greetings from the Netherlands
(3,952 Views)
please, if you can explain it in details, tell me. I am really need the help.
if i knew what  Dennis said, i will not posted it again.
thanks.
(3,949 Views)
select help/find examples in search type joystick and off you go.
(3,945 Views)
thanks.
now i understand it little bit. i need to know how to use it in changing slides Values. Do you know?
thanks.
(3,944 Views)
These are controls, update them via a local variable
(3,940 Views)
thanks very much. I made it Smiley Happy
(3,926 Views)
