J1939 Bam tutorial
Greetings,
I'm using the J1935 example shown here and I am able to transmit messages between two computers using it.
http://www.ni.com/example/31215/en/#toc16
HOwever my type field says CAN data and no J1935.  Has anyone else had an issue with that? I configure it using an ID of
0cf00401
and 8 bit message of FFs
(3,606 Views)
Hi Dmarcus79,
If you click on it, can you see J1939 in the pop-up menu? If it's missing there is something wrong with the XNET Frame CAN.ctl so take a look at it.
Regards.
(3,569 Views)
I can see it in the drop down menu but it reverts back to can message when new data is selected.
(3,547 Views)
That's actually an indicator. It's basically reading what you have in the bus. Meaning that you are acquiring a CAN message or it's reading it like that.
This is just an example so it's important you take a look at the code folder for the functions available.
Regards.
(3,543 Views)
