Issue with USB-232
OK - this is probably a fairly simple issue, but it is causing some issues that I am not sure how to resolve.  I am running LV 2013 on a 64-bit Windows 8 machine and I can not seem to get the computer to identify a USB-232 device from NI.  I am running Serial 4.0, VISA 5.4.  When I connect the USB-232 cable, a new entry in MAX under Devices and Interfaces called "NI USB Device Initialization".  I have no idea what this is or if there is something I am supposed to do with this.  Anybody have any thoughts.  All would be welcome.
Thanks, Matt
(6,672 Views)
Have you tried connected a serial device to the USB 232? Are you able to get any functionality? You've got the right drivers installed, so there's nothing strange there.
Nathan Murphy
NI C Series Modules Product Manager with an expired CLA
(6,608 Views)
Thanks for the reply Nathan.  Unfortunately, since the USB-232 is not showing up properly, there is no functionality regarding serial devices...
(6,526 Views)
Does it appear as a com port in windows device manager? If not, then perhaps you should try a repair or reinstall of NI-Serial. If it does appear, you can try a terminal emulation program suchas hyperterminal, putty, etc.
(6,505 Views)
Unfortunately, no.  It is showing up under NI-Serial USB/Expresscard perf with the heading NI USB Device Initialization.  If this sounds like Greek to you, forgive me... I have never had an issue like this before so I am not really sure what is going on....
(6,500 Views)
Accepted by topic author cirrusio
As I said, I'd recomend a reinstall of NI-Serial. I think that is the actual driver that makes it appears as a com port in windows.
(6,496 Views)
Reinstall seems to have fixed it.  Thanks, Dennis.
(6,489 Views)
