Is there a way to convert LabView code to C?
(4,090 Views)
To the best of my knowledge no. Many LAbVIEW functions are compiled directly to machine code apparently. Therefore the C-code does not exist for much of what makes up LV.
It's a common mistake to believe that LV programs have a C-program lurking somewhere in the background. This comes from the fact that the LabVIEW development environment was written in C. Hopefully most people will however recognise that this has nothing to do with the actual code produced by using the development environment.
As imilar comparison would be to ask if my WORD document is available in C++ because WORD itself was written in C++.
So the short answer to your question is no. If you require C-like code, try taking a look at LabWindows CVI. It's text-based.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(4,083 Views)
You can however build a DLL in LabVIEW with the Application Builder that can be called from C based environments.
(4,064 Views)
Are there any software or programs that can convert LabVIEW codings to C directly?! If there is, can anyone please share with me?
KW
(3,554 Views)
Did you try a search? This question has been asked MANY times. http://forums.ni.com/t5/forums/searchpage/tab/message?location=Board%3A170&q=convert+labview+to+c
(3,542 Views)
