Is there a 68 to 50 pin converter?
I have a new digital IO card (6533 or DIO-32HS) with a 68 - pin connector and I need to interface this new card with an older test system that has a 50 -pin header. The manual gives a conversion diagram for the two connectors, but is there one canned that i could just purchase? Or do I have to make up custom cables?
(4,480 Views)
I recently bought the NI cable adapter from 68f to 50m for E-series device (code 183139-01).
If I'm not wrong, for DIO-32HS there is a different converter with diffeent pin assignments: you have to check directly with NI persons, but I assume it's still possible to obtain it even if it's not in the catalogue.
Roberto
(4,481 Views)
Yes, there is a cable that converts the 68 to 50 pin. In the page 488 of the NI 2002 catalog you can find the cable R6850-D1 that is designed for this purpose.
I hope that helps.
(4,480 Views)
How about a 50 to 96 pin converter to connect an AT-MIO-64E-3 to a SXCI-1000 box?  Thanks
(4,165 Views)
Let's continue this in your other forum, here.
David L.
Systems Engineering
(4,139 Views)
