Is the GPIB-ENET/100 device compatible with GPIB ibln() function?
I am using a GPIB-ENET/100 device for the first time in a LabWindows CVI
project. I have an HP8903B audio analyzer as one of the GPIB devices.
I downloaded and am attempting to use the driver as indicated by the
following excerpt from the file;
/*= HP 8903B AUDIO ANALYSER ===============================================*/
/* LabWindows 2.3 Instrument Driver */
/* Original Release: August 1994 */
/* Dec 1999: changed ibwait mask in measure() from 0xc800 */
/* to 0x4100. */
When I attempt to initialize the unit from my CVI program using:
hp8903b_init (GPIB_ADR_HP8903B, 1, &iidHP8903B);
the following error is received:
NON-FATAL RUNTIME ERROR
"HP8903B.C", line 84, col 9
Function ibln: (iberr == 1 [0x1]).
I have traced through the device driver, and everything appears to be fine
up until the call to ibln(). I noticed the following in the help screen for
the ibln() function:
"from ibln() help panel"
Due to hardware limitations, this function is not
available on the GPIB-PC2, GPIB-PC2A, and GPIB-PC CONV
interface boards.
So apparently the ibln() function is not compatible with all GPIB hardware.
Does anyone know if the ibln() function can be used with the GPIB-ENET/100?
(3,575 Views)
Yes, IBLN does work on the ENET. I would suggest using IBIC (ibic.exe) as outlined at http://www.ni.com/support/gpib/max/ibic.htm as a means to determine if your bus is working properly. I might suggest adding an IBSIC call in your program to make sure you are taking control of the bus. The ECIC is typically the result of not having control.
(3,575 Views)
Thanks to Ryan for posting a response. His answer, as it turned out, explores the correct problem area. The problem was/is with the control card ud returned from the ibdev command. The value I get is 31,256 for whatever reason. NI support informed me that some people (depending on CVI version and OS platform) have experienced a software glitch if the value returned from ibdev is greater than 1024. I assume the issue is the declaration of a variable type to hold the value in some gpib dll.
I "patched" around it by removing the ibln call from the instrument driver that I was using. Don't know what this will mean if the program is run and the unit is not powered or on the gpib bus...
(3,575 Views)
