Is it correct using to power off the device of NI Linux suddenly?
I use the cRIO-9054 implemented NI Linux.
I'd like to know how to power off this device.
Is it correct using to power off this device of NI Linux suddenly?
Or should I use shutdown command?
Under my case, I don't want to use this shutdown command because my system can not detect opportunity of shut down.
(1,864 Views)
Hello
If you are don't want to power off your cRIO programmatically, the one and last way is simply power off your device from the power socket
(1,646 Views)
