Interfacing LabVIEW with FMD88-10 PLC via Modbus TCP/IP: Setup and Command Sending
Hello forum members,
I'm currently working on a project that involves interfacing LabVIEW with an FMD88-10 PLC using Modbus TCP/IP over Ethernet LAN. I'm seeking guidance on how to set up this communication from scratch, including the exact steps for configuration and sending commands.
Specifically, I need help with the following aspects:
  1. Modbus TCP/IP Configuration: How do I configure the FMD88-10 PLC to communicate over Modbus TCP/IP? Are there specific settings or parameters I need to set on the PLC?
  2. LabVIEW Configuration: What steps are required to configure LabVIEW to communicate with the FMD88-10 PLC using Modbus TCP/IP? Do I need to install any additional libraries or drivers?
  3. Command Sending: Once configured, how can I send commands from LabVIEW to the PLC and receive responses? Are there any examples or templates available that demonstrate basic command sending and receiving using Modbus TCP/IP in LabVIEW?
Message 1 of 1
(428 Views)
