Instrument control
Hi
I have 28 bytes data packet in HEX which are sent from my device at 27 Hz. Each packet carries seven measured values (temperature, voltage, pressure...) in 4 bytes HEX little endain. I want to sort  the 28 bytes HEX in 7 elements array, reverse and then convert them into 32bits floating point. Can you please give some hints how to do that.
(3,578 Views)
Hi Shimbloo,
Thanks for posting on the discussion forums.  One thing you can do is run the array through a for loop, and an inside the for loop use the Reverse String.vi (Functions Palette >> String >> Additional String Function) and then run it into a Hexadecimal String to Number.  It gets converted to a I32.  I hope this helps out.
Michael
Applications Engineering
(3,549 Views)
Thanks for your help , my program is working now
(3,512 Views)
