Installation gpib problems with windows xp
Will not pass the test Interfaces Squentially Verified..No hardware conflicts..System Device manager indicates that this device is working properly. Computer is running a AMD 1700XP processor..
(3,101 Views)
Hi Perk,
Often times this happens when there is an instrument connected to the GPIB device when the test is run. You should be able to remove the cable and pass the test. I would recommend just moving on to communication with the device. Use scan for instruments or IBIC to verify that you care able to talk with your instrument.
Best Regards,
Aaron K.
Application Engineer
(3,101 Views)
