Input Buffer Overflow (error 521) using VISA Write to 34970
The "operator error" I mentioned before was, if I recall correctly, that I was addressing the wrong slot in the HP34970.  All three slots were being used, but I had at some point swapped the position of the relay and 20-channel multiplexer cards.  But my LabView code did not yet reflect this.  So, I had the channels numbered as 201, 202, 203,... when they should have been 301, 302, 303,...
So, a 'bug' in the code that I introduced.
Troy
Message 11 of 12
(1,521 Views)
Thank you,Tory.I didn't have the "operator error",I guess I have to check my VI carefully to find out my errors .Anyway,thank you very much.
    jiacheng
帖子被emptytiger在 04-12-2010 10:11 PM
时编辑过了
Message 12 of 12
(1,503 Views)
