Incrementing Function Generator using Labview
Good afternoon guys! so i am new to this and have been working on incrementing the Panasonic VP-8132A.
Not sure how to make this work. I have exhausted all my options here.
Attached is what i have so far, if anyone can help me....at least to point me in the right direction, i will appreciate it.
Thanks.
(3,705 Views)
You had nothing connected to the case statement, the inner and out while loops had nothing wired to the conditional terminal, and you had nothing wired to the right side of the shift register. I could see no reason at all for the inner while loop and I'm guessing what the case statement is for. I made this a little more flexible to allow you to specify the start point, the increment, the stop point, and a loop delay. I replaced the GPIB Write with a VISA Write as VISA is generally the prefered GPIB communication method and added error in/error out connections. O prefer to use the Format Into String instead of the separate functions you have for creating the command. Other than that, I didn't need to change much at all.Smiley Wink
(3,699 Views)
Dennis, Thanks! funny...you changed everything  Smiley Happy
One mor question: How can i change the GPIB address to what my address is?
(3,695 Views)
The VISA Resource Name control has a little arrow on the right side. Just click it and you will get a list of all resources. Pick the one that corresponds to your instrument. It will be something like GPIB0::11::INSTR. You can also assign an alias to a resource in MAX. You could call it something like FuncGen. Typing the resource name or alias into the ontrol also works.
(3,691 Views)
Dennis, sorry to bother you! it works!! you are such a blessing!
Thanks!
(3,689 Views)
