07-25-2014 11:09 AM
07-28-2014 12:37 PM
Hello Bruce,
Do you know what update it was, for which software?
Please post back with a screenshot of how the cards show up in both NI MAX and the Windows Device Manager; this helpful for me to understand what is going on.
Also, what cards do you have, and does this happen to all of your cards, or just some?
07-29-2014 09:13 AM
Here is the report for what I am seeing when I first start up MAX. The error code said “NI Service Locator is not running”, See attachment.
I use this NI Software to calibrate PXI cards listed below using a NI PXI-1033 mainframe. PXI cards are:
PXI-4070
PXI-4461
PXI-5441
PXI-5600
PXI-5610
PXI-5620
When I run Calibration Executive to calibrate a PXI-5600, I see the error code “Error-603 occurred at Open RegistryKey.vi at step Query Driver Versions.
Possible reasons: LabVIEW: Specified key or value does not exist.
When I run Calibration Executive to calibrate a PXI-5620, PXI-5122, I see the error code “Error 1003 occurred at Open VI Reference in cex_ReadDriverVersion.vi-
>cex_FindProcedureINIAndGetVersionInfo. Vi-
>cex_FindProcedureINIAndGetVersionInfo. Vi.ProxyCaller
VI Path: C:\Program Files\National Instruments\Calibration Executive\Source\vi.lib\
ProcessModel\QueryDriverVersions\specificDrivers\cex_Read_NI_SCOPE_Version.vi
At step Query Driver Versions
LabVIEW: The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Open the VI in LabVIEW using File>>Open and verify that it is runnable.
Possible Reasons:
LabVIEW: The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Open the LabVIEW using file>> Open and verify that it is runable.
When I run Calibration Executive to calibrate a PXI-5620, I see the error code “Error 1003 occurred at Open VI Reference in cex_ReadDriverVersion.vi-
ProcessModel\QueryDriverVersions\specificDrivers\cex_Read_NI_DMM_Version.vi
Possible Reasons:
When I run Calibration Executive to calibrate a PXI-5610, I see the error code “Error 1003 occurred at Open VI Reference in cex_ReadDriverVersion.vi-
ProcessModel\QueryDriverVersions\specificDrivers\cex_Read_NI_RFSG_Version.vi
LabVIEW: The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Open the VI in LabVIEW using File>>Open and verify that it is unable.
Possible Reasons:
When I run Calibration Executive to calibrate a PXI-5441, I see the error code “Error 1003 occurred at Open VI Reference in cex_ReadDriverVersion.vi-
ProcessModel\QueryDriverVersions\specificDrivers\cex_Read_NI_FGEN_Version.vi
Possible Reasons:
I can successfully calibrate a:
PXI-4461
