IVI .NET ResourceManager Find Method response incomplete?
I am trying to use the IVI .NET VISA SW components to interface my Instruments with MATLAB.
Using NI VISA Interface Control SW (and clicking "refresh"), I am able to list and see all the interfaces.
And the NI IO Trace acquisition shows 8 interfaces :
I am interested in the last one in the traces: the instrument on GPIB...
Now, I am using the IVI .NET VISA SW component.
Running the Find() method of the GlobalResourceManager class, the result is different !
The number of detected interfaces is reduced to 6 instead of 8?
I have lost the GPIB ones, unfortunately.
I am using : Ivi.Visa.GlobalResourceManager.Find('?*') or Ivi.Visa.GlobalResourceManager.Find() - with same result.
And when running this line, the NI IO trace shows:
Only serial interface are listed here and no longer GPIB ones.
What is the difference between what is done by the NI VISA interactive control SW and the ResourceManager.Find() method I am trying to use?
Shall I do something different, what am I doing wrong?
Thank you in advance for your help and advice.
Laurent
(3,593 Views)
Hi lmart,
What version of NI-VISA and NI-488.2 did you install on your computer?
Did you try to open a connection to the GPIB instrument by using the name displayed in NI-MAX?
Did you try to research specifically the GPIB using this expression: GPIB?*INSTR ?
Clement
(3,536 Views)
Hi Clement,
I have installed the latest versions : NI-488.2 20.0 / NI-VISA 20.0 and NI-ICP 20.0
I should be up to date regarding NI drivers and NI SW components.
Using NI-MAX, I am able to detect my instrument on GPIB::4::INSTR, then I am able to open a VISA connection and send + receive commands => with NI-MAX and NI VISA Interactive Control SW everything works quite fine.
But using .NET interface with MATLAB, when trying to open a connection to the same GPIB address = 'GPIB::4::INSTR' as mentioned in NI-MAX, I encounter an error. The IVI .NET Open() call did not succeed => VISA Error 0xBFFF00A5 (VI_ERROR_INTF_NUM_NCONFIG) returned as error.
I opened a dedicated thread on this error too => https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/VISA-Error-0xBFFF00A5-VI-ERROR-INTF-NUM-NCON...
I also tried many .NET Find() calls with numerous query strings ('?*', 'GPIB?*INSTR', ...) but here again, no success.
It is like .NET interface is filtering in some way the USB-GPIB adapter ???
Many thanks for your help.
I am still trying to understand the issue, because everything is OK with NI tools 😞
Laurent
(3,524 Views)
