IP interface KNX
Hello, I have an IP interface KNX. Anybody knows how can I work with this in Labview?
Thanks for comments,
Jenny
(6,017 Views)
Hi jein!!
Thank you for using NI Discussion Forums!!  While there is no specific Communication API for KNX in LabVIEW, you can use OPC Servers to connect with your device.  The OPC Foundation has released three major versions of the OPC specification. LabVIEW currently supports the following versions of the OPC DA Specification:
  • Version 1.0—DataSocket Client.
  • Version 2.x—DataSocket Client, Variable Engine OPC Server, (DSC Module) DSC OPC Client.
  • Version 3.0—Variable Engine OPC Server, (DSC Module) DSC OPC Client.
If you look up the OPC foundation site linked http://www.opcfoundation.org/Products/ProductDetails.aspx?CM=1&RI=8303&CU=1, you will find that this server uses DA 2.0. So you should be able to access it using Datascokets or DSC, although I have not found any tests that prove the compatibility.
Hope this helps!
Regards!
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(5,992 Views)
Check KNX's web site for the model of your unit. They may have an SDK and .Net dll's you could call from LabVIEW.
-AK2DM
(5,983 Views)
