I2C Advanced API for C with NI-8451
i want to use a humidity sensor with an i2c comunication sequence described in the attached file. Using the NI-845x basic I2C API i get a communication error. Therfore i have to program a script with the advanced i2c API. Can anyone help me how to use the ni845xI2cScriptxxxx commands (for c) to map the communication sequence of this sensor ?
Thanks a lot !
(4,943 Views)
Thanks a lot !
Are you or your manager willing to pay this person to write the code for you?
(4,934 Views)
Hey Nyc,
what kind of help do you need? The communication sequence for your humidity sensor doesn't contains anything, which is not a normal I²C communication. Which error do you receive if you uise the basic I²C API? An error reported by the API can be a result of wrong cabling, missing termination resistors, logical issues and so one.
You will receive more attention from the forum user, if you attach you current code too.
Stephan
(4,912 Views)
Hey Stephan,
i think, the challenge consists in mapping the "transmission start" sequence !!!
i've attached my current code. After the write / read command i get the error code = -301742: "slave can't recognize the address and the direction byte of the i2c master"
(4,905 Views)
I think the transmisson start sequence only looks a little bit confusing, but is the regular start condition for an I²C transmission. The start of a transmision is defined as the falling edge of the Data line during a high signal on the SCK (Serial Clock) line.
I2C Bus Specification
http://i2c.info/i2c-bus-specification
And if I take a look into the communication sequence, the last part of the transmission start is a falling edge of the SCK line during a high signal of the Data line. I think the picture should show that you need this special transision and any other changes of the SCK and Data line are ignored.
Stephan
(4,901 Views)
