I wqnt some help constructing an interface for Labview for a controller
(3,797 Views)
What type of controller are you talking about? You're going to have to provide a lot more information.
(3,795 Views)
Thank you for your input! I have a eurotherm 902 controller on a furnace and want to program using rs232 connection for thermal cycling
(3,793 Views)
on a PC using Labview...
(3,791 Views)
I'm not familiar with the Eurotherm but a recent thread on a different model can be found here. There are some drivers for other models here. I hope that there's enough there to get you started. You should also study the shipping examples on serial communication and you're going to need the programming manual for your controller. As a general subject, I'm pretty sure that you could find some example code on temperature cycling. Try searching the forums and see what you can find.
(3,785 Views)
hi gary
I want also to do the same thing, can you send me the vi to controll the eurotherm 902, thanks
(3,615 Views)
