I was not able detect Ines GPIB-PCI-XL card in MAX.
I was using  Ines GPIB-PCI-XL card to communicate with different GPIB instruments, unfortanetly i am not able  to detect the card in MAX. i am using Lab VIEW 8.5.
Can any body help on this.
Mahesh.
(4,296 Views)
Since MAX is a utility program from National Instruments for the configuration of National Instruments boards, it would not make any sense to try and use it to configure a board from another vendor so this is normal behavior. Since you say you are able to communicate with instruments, and the Ines web sites says it supports LabVIEW, do you have any other problem?
(4,289 Views)
I got the solution!!
We need to uninstall NI VISA and install Agilent IO Libraries.
Then we can start programming using VISA in LabVIEW.
Mahesh.
(4,276 Views)
That makes no sense to me. Why would you install Agilent software for the Ines controller? Did you get that information from Ines? If you are having problems, you should be installing the Ines version of VISA.
(4,270 Views)
