I want to know the NI PCMCIA-RS485/2 can support the 307200 baud rate or not.
In our application, RS422 communication with the 307200 baud rate will be used.
I want to know the NI PCMCIA-RS485 card is available with that baud rate or not.
Can you check the availability of that baud rate ?
I will expect your answer as soon as possible.
(3,520 Views)
Yes, you will be able to use that baud rate with a PCMCIA-RS485 serial device.  The PCI/PXI 8431 device can also use that baud rate if you need a non-PCMCIA option.
Best of luck!
Chris R.
National instruments
Chris R.
(3,498 Views)
(3,247 Views)
