10-10-2012 04:42 PM
I design photo current system:CM 110 monochromator, keithley 2400 gpib
I change the wavelength from CM 110 and I read the current from 2400.I need to control this system over labview.
I need to read current with gpib connection of the keithley 2400. Could someone tell me how to do that??
I checked the other topic solutions but there's no exact solution for me. Thanks in advance
10-10-2012 07:16 PM
Do you have any drivers? If not, use the LabVIEW Instrument Finder to download the Keithley 2400 drivers. There should be a VI in the library to read the measurements.
10-11-2012 11:38 AM
Yes,I have some drivers,and some dont.
I have keithley 24xx and CM 110 drivers but they dont solve problem properly enough
10-11-2012 12:19 PM
10-11-2012 12:44 PM
@Dennis_Knutson wrote:
You have two instruments and you say you have drivers for both so it would seem you have everything to get started.
You have not mentioned your exact problem and what it is about the drivers that does not solve it.
I think the problem it doesn't solve, is that he has no experience with any of this.
