I'm looking for ph and conductivity sensor to connect to my usb 6008 (uses terminal block)..sal2
Greetings All,
I'm looking for a PH and a conductivity sensor to connect to my usb 6008. The usb-6008 uses terminal block connectors
are there any ph/conductivity sensors that connect directly to the terminal block or do I need to use adapters. If so can anyone recommend a sensor or adaptor (if needed)
sal2
(3,547 Views)
Take a look at www.omega.com. They make ph/conductivity probes. You will also need signal conditioning to bring the level of the probe outputs up to the input range of the 600x units.
Dave
(3,546 Views)
You can find probes with embedded conditionning amplifiers. Have a look here for instance. Some are very cheap.
CC
Chilly Charly    (aka CC)
(3,541 Views)
