Hp 3589a driver needed!
Hi!
Anyone has the labview driver for Hp 3589a network analyzer? Thanks!
(3,723 Views)
Hi happybird:
I could not find any drivers for this instrument.  You can always put a driver request in on NI's idnet.  Also, you can use the Instrument I/O Assistant or just regular VISA code to communicate with your instrument or even write your own instrument driver.
Emilie S.
(3,713 Views)
Hellow!
Could you please let me know more detail about   "Instrument I/O Assistant"? does it come with the labview? thanks!
(3,709 Views)
Hi happybird:
That depends upon what version of LabVIEW you have.  Assuming you have LabVIEW 7.1 you can find the Instrument I/O Assistant, in the Instrument I/O palette from the block diagram.  If you put one on your block diagram it will open up a wizard that will let you set up some code that will initialize your instrument, then write to and or read from it.  This is a way to do some basic communications.
I have attached some basic VISA code to this post also, that should get you started.
Emilie S.
(3,680 Views)
