How to send 12 bit on serial port
I was working on sending the 12 bit by dividing it into two bytes for example 111111000000 will be 00001111 & 11000000 in this way if I read 16 bit the value won’t change. I tried to rejoin the bits in labview using the type cast after the string then U8 then index array then join numbers, but I couldn’t plot the signal on a graph I think it’s because I don’t have an array of points to plot just one point.
So if that’s the problem can any body tell me how to put the points in a new array?
            I attached the VI with the massage. The problem is at the receiving loop.
Thank you
(3,378 Views)
duplicate post. Why are you starting a new thread when you already have one on the same question?
(3,373 Views)
Sorry I thought I could send the same messege on differrent boards
(3,363 Views)
