How to display serial waveform using Labview??
I'm a newbie in Labview Programming. Is it possible to display the serial waveform on the display using Labview?
From
Don
(3,386 Views)
Don,
I'm not sure that I understand what you mean by 'serial waveform'...You can graph an array of data points quite easily in LabVIEW using the Waveform Graph found on the 'Graph' palette...Please fill me in some more and we'll see what we can do!
Craig H.
NI Applications Engineering
(3,371 Views)
