How to connect a valve to a PI 6024E...
I need some good advice about connnecting a valve to a NI 6024E board and to know what other board I can use to connect a valve to it which has more than two outputs.
I am trying to switch the valve on/off for two different voltages and two different time voltages, I already can switch them once, but I need them for an x time given by user. If someone has some example or suggestion I will appreciate it a lot.
Julieta.
(3,296 Views)
The usual way to control a valve (coil) is to use an digital output instead of the analog voltage output. Your 6024 has about 4 to 8 of them (Look at the spec) called DIO (digital input or output, you can define it with the daqmx driver). Since the output has usually not enough power (current) to drive a valve directly you need a external power source and a driver.
Cheap with a some work and soldering: a transistor with some resistors and protection diode ..
Easy: SSR, a solid state relay with optocoupler and screw terminals
If you tell us more about your valve (link to datasheet) we can provide a more precise answer.
Greetings from Germany
Henrik
LV since v3.1
(3,275 Views)
