How to connect a IEEE 488 port to the windows XP PC with Labview software
Hello all,
  I am new to LABVIEW and hence this is a very simple question. I have this temperature controller (Lakeshore 330 autotuning Temperature controller) with a IEEE 488 port in the back. I want to control it via LAbview 7 installed in a windows XP PC. The idea is to - 1. set the temperature via labview 2. let the controller stabilize 3. once step 2 is over, tell a Multi channel analyzer card to start taking data (this card takes signal from a gamma detector and is not connected to the temperature controller).
Can anyone suggest me a brief/detailed way to do it?
Thanks in advance.
saurabh
(4,838 Views)
start with buying a NI-gpib card.
Install the software and connect the cable to the instrument
start MAX to check the connection and find instruments
Download a driver from ID net or from the instrument manufacturer and up you go
greetings from the Netherlands
(4,834 Views)
Hello Albert,
 Thanks for the reply. I looked around in the lab and found a PCI-GPIB, IEEE-488.2 card (https://www.ni.com/en-us/shop/model/pci-gpib.html) and the cable (part number- 763061-02, Type X2).
The question that I have is do I still need to buy the NI-GPIB-USB controller (https://www.ni.com/en-us/shop/model/gpib-usb-hs.html). Can't I just connect the PCI-GPIB card to the temperature controller?
  The questions are obviously stupid as this is my first experience with labview based automation. Thanks in advance
saurabh
(4,808 Views)
Hi
for me a nobrtainer after 30 years of automation, but indeed the only thing you need is a cable and that pci-gpib card.
(4,806 Views)
Jesus , man! you are fast. Thanks and I will bother you more if there is some problem, which might be aplenty!
saurabh
(4,805 Views)
I would also suggest looking over the material here for basic information and howtos: http://zone.ni.com/devzone/cda/tut/p/id/4359
(4,796 Views)
