How to change the interface number when the PC has multiple GPIB I/F?
I installed a PCI-GPIB onto my Vista computer. It was assigned gpib0. It worked perfectly. Then, I connected a USB-GPIB-HS to one of the USB ports. It was recognized as gpib1. It worked perfectly, too. Now, the question is: are there any ways to swap the board number without removing the PCI-GPIB board from the computer? I want to assign gpib0 for the USB-GPIB-HS and gpib1 for the PCI-GPIB.
(5,516 Views)
The GPIB Interface properties in MAX should allow you to change the GPIB interface ID.  That works for me with Windows XP and GPIB drivers V2.5. But I couldn't test that with VISTA.
(5,505 Views)
Markus,
MAX did allow me to change it. Thanks for your help. In Vista, I needed to start MAX with the "Run as admin..." option to be able to change it.
Tetsu
(5,494 Views)
I need to change GPIB1 to GPIB0. There is only one GPIB interface. There is no drop menu to change it. I have administrative rights on the PC.
(4,970 Views)
Joe,
Try going into Properties in MAX.
Brian H. -- Electronics & Measurements Product Marketing Manager
(4,957 Views)
I haven't found it possible to change the interface number.
(4,954 Views)
When you have admin rights it should be easy in max.
Select properties and change the address
greetings from the Netherlands
(4,944 Views)
