How may I change <repCapIdentifier> in <Channel> in a labVIEW Wrapper created trough Import Generator Tool
Hi everybody
I have an issue with a name largely used in IVI standards that gets translated as is from a .fp, .h LabWindows/CVI files into LabVIEW wrappers. The name is <repCapIdentifier> and is the IVI standard name for an instrument channel. There are people that would prefer to see instead of <repCapIdentifier> the more familiar name <channel>.
The problem is that the source files build for LabWindows/CVI contains <repCapIdentifier> as a parameter name and the Import Generator Tool let me change only the function name not the name of parameters.
I tried to change the <repCapIdentifier> into <channel> in the corresponding .h header file of the CVI driver but still the final LV wrapper keep the <repCapIdentifier> name for a channel.
I could go in each final LV wrapper and for every one of them replace the label <repCapIdentifier> to label <Channel> but there are so many of them and sometimes created for multiple times that the task becomes tedious.
I wonder if anyone on this board got involved in this <repCapIdentifier> naming issue and if so what was their solution.
Sorin
(4,448 Views)
Which Import Generator Tool are you using? Is it something from National Instruments?
(4,429 Views)
Hi Olivia
Yes, The Import Generator Tool that I am using to create LabVIEW wrappers is from NI.
Depending on LabVIEW version it is named "Import CVI Instrument Driver" or "Generate VI  Interface from CVI Driver" and install as a Tool add on labVIEW under Front Panel => Instrumention  menu.
The name of tool driver on NI site is <driverctolv.exe> for LabVIEW 7.1 or <driverctolv_1.2.exe> for LabVIEW version 8.x.
Sorin
(4,422 Views)
Hi Sorin,
I'm not too familiar with the Import Generator Tool. I'll have to get back to you on that.
(4,402 Views)
Hi Sorin,
The Import Generator Tool is basing the control names on what is found in the .fp file. Changing the labels in .fp file might make things a little easier for you.
If you would like, you could post the driver you want to import into LabVIEW and we can take a look at it and offer any suggestions.
(4,366 Views)
Hi Olivia
Yes your sugestion is good.  I was able to change the label <repCapIdentifier> in all .fp file through one Edit->Replace operation. I supposed that if the .fp file is changed also all LV VI wrappers generated from this file will propagate now <channel> instead of <repCapIdentifier> but I have to test that tomorow and let you know the result.
Sorin
(4,358 Views)
