How do I import USB control to python? I want to write read to instrument that has USB interface.
How do I import USB control to python? I am using python 2.5. I want to write read to instrument that has USB interface.
Chanh
(5,808 Views)
Please tell us more about the instrument, you want to control. If it supports the USBTMC standard and comes with a´documented command language, you should have a look at pyvisa. However if the instrument uses undocumented vendor specific protocols, you will get problems to control it over USB.
(5,803 Views)
Thanks for your help. I have statement "import visa" which came from NI visa. Will that work for usb? Instrument I control is Agilent DSO91304 oscilloscope and USB relay cards designed by EASYDAQ. For EasyDQA relay card command was simple:
C (43H), 102 to close relay. I hope using USB will be something like open port, write text to port and close port.
(5,794 Views)
Hello Chanh Vo,
It sounds like you should look into pyvisa.
Jeff L.
(5,782 Views)
For a start look at the three liner example for the Keithley multimeter given at http://pyvisa.sourceforge.net/.
You just have to adapt  the Parameter in visa.instrumemt  to the id for your USB instrument. Check Measurement and Automationexplorer for you instrument. It will show you that id string
(5,777 Views)
