How can the attributes of an instrument be changed and saved?
I'm trying to control an Anritsu network analyzer via GPIB.
I'm getting an error when connecting it, and I found that problem was probably coming from the way that the command has to terminated. Therefore, I need to change the state of one parameter to the instrument, concretely it's the VI_ATTR_TERMCHAR_EN attribute, that has to be from false to true changed.
I've tried to change this attribute with the Visa Assistant of the NI-MAX, there I can change the attribute and I get a return value of 0. But when I reopen the application and I retrieve the value of the parameter I can see that parameter hasn't changed.
Somebody experienced this problem before? ... Do you have any hint on where the problem can come from?
Many thanks,
Miquel
(3,286 Views)
Why don't you just set the attribute in your program?
(3,275 Views)
