How can I use IVI for Agilent 34401 in LV8.6.1,I only discover IVI driver for LV8.5.1 .
How can I use IVI for Agilent 34401 in LV8.6.1, I only discover IVI driver for LV8.5.1, the highest version .
I installed the IVI for LV8.5.1, but I couldn't setup in MAX.
Thanks!
(3,318 Views)
The driver is compatible with 8.5 or higher and the LabVIEW version is irrelevant in MAX. Exactly what do you mean you could not set it up?
(3,315 Views)
Accepted by topic author kelai
Thank you, the problem is solved. But strangely, after I reinstalled the IVI driver, it could be setup in MAX.
(3,312 Views)
