I am searching for a copy of GPIB-NT.COM. Any help is appreciated.
John
(4,201 Views)
There is a great Developer Zone article that addresses running DOS and Win16 GPIB applications on Windows 95/98 and WindowsNT at:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/0bb66dab3253244e86256804006a96ba?OpenDocument
Here is a small excerpt of that article...
Running DOS Applications Under Windows NT
To run your existing DOS GPIB applications, load the special GPIB device driver gpib-nt.com instead of gpib.com, which you would normally use with DOS. When you install the NI-488.2M software, gpib-nt.com is copied into a new sub-directory called doswin16. To use gpib-nt.com, you must modify your config.nt file to load gpib-nt.com whenever a DOS application is executed. The config.nt file is located in your \system32 directory, whe
re is your Windows NT directory, for example c:\windows. To load gpib-nt.com, add the following line to your config.nt file:
device=\doswin16\gpib-nt.com
where is the directory where you installed the GPIB software (the default installation directory is c:\gpib-nt).
You can now successfully execute your DOS GPIB applications.
(4,201 Views)
You can download drivers from http://www.ni.com/support/gpib/version.htm
Select the DOS link and then download the driver corresponding to your particular device.
Ryan Mosley
(4,201 Views)
The link for GPIB Driver information is actually http://www.ni.com/support/gpib/versions.htm
Shannon Rariden
(4,201 Views)
