Handling data from an A/D converter (serial device)
Sorry for the delay.
You were right: When the connections are fixed in the "false" case
and the initialization done in the "true" case - this solution works nicely!  Smiley Happy
Do you understand, why the shift register doesnt have to be manually initialized _before_
running the while loop? I would have expected this to be necessary..
As far as I understand, the initialization is done with the first run of the while loop.
Christian
Message Edited by fumic on 07-16-2009 06:47 AM
Message 11 of 12
(1,105 Views)
Hi Christian,
no it's not necessary. See this link for more information on it.
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=240328#M240328
Mike
Message Edited by MikeS81 on 07-17-2009 08:08 AM
Message 12 of 12
(1,095 Views)
